Welcome to the RAS Solution Forums HEC-RAS Help Get rid of “missing files” warning
  • #7286
    Geo_Wick
    – deleted –
    #12210
    The program looks for whatever files are listed in the *.prj file. If you hit save after you see that message, they will be removed from the *.prj file. The other option is to delete them from the *.prj file, which is what I normally do.
    You also have to make sure that whatever is listed in each plan file (*p01) still exists (*.g01, *.f01, or *.u01).
