Welcome to the RAS Solution › Forums › HEC-RAS Help › GeomPreprocessor.exe has stopped working
  • #5641
    Scott La Vanne
    I’m performing an unsteady flow simulation in HEC-RAS 4.1.0. When I run the geometry preprocessor, the progress bar goes all the way to the end and appears to finish. Then before the Unsteady Flow Simulation begins I get the error, “GeomPreprocessor.exe has stopped working”. Nothing proceeds from this point until I click “Stop”. Has anyone encountered this error before? Plugging the error message into Google yields less than two pages of results, none of which have been helpful.
    I created the geometry using HEC-GeoRas then modified the more complicated elements within HEC-RAS.
    Things I’ve already tried:
    – Restarting the computer
    – Filtering the Cross Sections
    – changing universal HTAB parameters
    – exporting the geometry data and reimporting into an entirely new project file.
    The only option left I can think of is starting over with rebuilding the geometry from scratch and hope I don’t get the error again. I’ve already invested a lot of time into the geometry so I’d obviously like to avoid that.
    Thanks for any insight you might provide!
    #9017
    Scott La Vanne
    For anyone else who may come along later with the same error this is what I have learned.
    1. the geometry worked in a steady state simulation so I suspected that a geometric element that is only active during unsteady simulations was to blame.
    2. I isolated the problem element to a single lateral structure that connected two parallel reaches. Deleting the structure allowed the unsteady simulation to run. Despite many attempts to revise the structure and channel geometry I could not get the simulation to run with the structure present. There are multiple other very similar lateral structures present in the model that do not create this problem. I don’t know what made this structure unique.
    I eventually decided that the structure wasn’t critical to the results I was interested in, and not worth investigating further. If anyone comes along with further insight I’d still be interested to hear your thoughts.
