Welcome to the RAS Solution › Forums › HECRAS Controller › Geometry Class: subroutine NodeCutLine_Points
- This topic has 2 replies, 645 voices, and was last updated 10 years, 12 months ago by Solomon.
April 16, 2015 at 8:48 pm #8162SolomonParticipant
Hi Chris,
Thank you for this forum!
I am using Python for working with river geometry using the RASController. I am using your book for this, but I am unable to understand how this call is made. I tried a few combinations – trial and error but didn’t work it out yet. Is there any documentation or example usage/code for this subroutine anywhere?Thanks,
Solomon.April 28, 2015 at 10:55 pm #13480SolomonParticipantAfter a couple of more tries, I am almost on the verge of giving up using the RASController for extracting the X,Y co-ordinate points from geometry files.
I know the alternate way of doing it is through direct text mining of the .g* files, but I could really benefit from any previous experience anyone has had in this with the RAS controller. Its worthwhile using the controller because the different versions of HEC-RAS perhaps have different formats of text file (I guess) and I am hoping the controller accounts for that.
Solomon.May 5, 2015 at 9:54 pm #13481Chris G.KeymasterHi Solomon. Sorry for the delay in getting back to you. Try the Schematic_ReachPoints subroutine for xy coorindates of rivers/reaches. Schematic_XSPoints will get you xy coordinates for the cross sections.
Here’s a simple subroutine that I wrote for RAS Version 5.0 beta to demonstrate the use of Schematic_ReachPoints. Just copy and paste it into VBA. the mSamples.OpenRASProjectsByRef subroutine that I call has mSamples in front of it because I have it in a different module, called mSamples. You could put the OpenRASProjectsByRef subroutine in the same module, in which case just drop the mSamples part.
Sub Schematic_ReachPoints()
‘Demonstrates the Schematic_ReachPoints Subroutine.‘Written by Christopher Goodell
‘July 31, 2014‘Returns arrays of rivers, reaches, and _
arrays of x and y coordinates for each reach. All _
array parameters are zero-based for this subroutine.‘Tested with the JUNCTION.prj data set. Any HEC-RAS _
project will work.
‘**********************************************************‘Open an HEC-RAS Project
Dim RC As New RAS500.HECRASController
mSamples.OpenRASProjectByRef RC‘Get the number of reaches
Dim lngReachCount As Long
lngReachCount = RC.Schematic_ReachCount‘Get number of all of the reach points.
Dim lngAllReachPointCount As Long
lngAllReachPointCount = RC.Schematic_ReachPointCount‘Dimension the arrays
Dim strRiverName() As String, strReachName() As String, _
lngReachStartIndex() As Long, _
lngReachPointCount() As Long, _
dblReachPointX() As Double, dblReachPointY() As Double‘Redim to zero-based arrays
ReDim strRiverName(lngReachCount – 1)
ReDim strReachName(lngReachCount – 1)
ReDim lngReachStartIndex(lngReachCount – 1)
ReDim lngReachPointCount(lngReachCount – 1)
ReDim dblReachPointX(lngAllReachPointCount – 1)
ReDim dblReachPointY(lngAllReachPointCount – 1)‘Get the arrays
RC.Schematic_ReachPoints strRiverName(), strReachName(), _
lngReachStartIndex(), lngReachPointCount(), _
dblReachPointX(), dblReachPointY()‘Clear the Output spreadsheet
Sheets(“Output”).Select
Cells.Select
Selection.ClearContents‘Write column headers
Range(“A1”).Select
ActiveCell.Value = “Reach Points”
ActiveCell.Offset(1, 0).Activate: ActiveCell.Value = _
“River”
ActiveCell.Offset(0, 1).Activate: ActiveCell.Value = _
“Reach”
“X Coord”
“Y Coord”
ActiveCell.Offset(0, -3).Activate‘Write Data to Output Spreadsheet
Dim i As Integer, j As Integer
For i = 0 To lngReachCount – 1
ActiveCell.Value = strRiverName(i)
ActiveCell.Value = strReachName(i)
For j = lngReachStartIndex(i) To _
lngReachStartIndex(i) + lngReachPointCount(i) – 1
ActiveCell.Value = dblReachPointX(j)
ActiveCell.Value = dblReachPointY(j)
ActiveCell.Offset(1, -1).Activate
Next j
ActiveCell.Offset(0, -2).Activate
Next i‘Close HEC-RAS
RC.QuitRASEnd Sub
Sub OpenRASProjectByRef(ByRef RC As RAS500.HECRASController)
‘Demonstrates Project_Open subroutine and how to pass the _
HECRASController as a reference.‘Written by Christopher Goodell
‘July 3, 2012‘Opens a RAS project by being called from another _
subroutine
‘**********************************************************‘Open the HEC-RAS Project
Dim strFilename As String
Sheets(“RASProjects”).Select
strFilename = Range(“C4”).Value
RC.Project_Open strFilenameEnd Sub
