Welcome to the RAS Solution Forums HEC-RAS Help Generate Portion of Report
  • #7081
    I have a very large HEC-RAS file with hundreds of cross sections and bridges but I only want to generate a report for four of the cross sections and one bridge. Is there a way to do this or do I have to generate a report for the entire file and just delete out everything I do not need?
    Carter
    #11826
    Yes you absolutley can.
    Click the standard table 1 button on the RAS main menu
    Then click options>define table
    On the “additional Options” tab you can specify cross sections within a cerntain number of nodes
