Welcome to the RAS Solution Forums HEC-RAS Help Gates – cant delete user defined performance curves
  • This topic has 0 replies, 1 voice, and was last updated 4 years ago by uke.
  • #15519
    uke
    I have a full 2D model (one domain) with a gate (I’m using user defined elevation/discharge curve) inside a SA/2D connection. Everything was running ok, but after adding a second user defined curve for that gate, my model wont run anymore – I keep getting “Error writting geometry file (hdf version)”. If I delete the gate, model runs OK again, so I’m certain that second curve is causing problems.
    I cannot delete my user defined curves, as delete icon on the menu doesnt work. Does anybody else have that issue, if so it’s probably a bug. If not, is there any other solution/option to delete those curves.
    I’m using HecRas 6.1.0
    U
    • This topic was modified 4 years ago by uke.
