I would appreciate some help/advice on optimizing a lateral structure on a stream.
There is a lateral structure modeled as weir on the main stream. After 3 RS at the d/s of the structure, this main stream is splitting in one additional “Bypass stream”. Tail water connection at the lateral structure was set as the first RS (most u/s) of the “Bypass stream”.
I was trying to optimize flows in the lateral structure and the main stream. The result flows from lateral structure optimization (Flows at d/s of the lateral structure and leaving it) does not add up to the flow in the u/s of Lateral structure. The difference in flows is highly considerable.
I have a schematic which I can post if someone ask me.
Any assistance would be greatly appreciated!!
