Welcome to the RAS Solution Forums HEC-RAS Help flow value (CFS) results within the 2D area
  • This topic has 4 replies, 483 voices, and was last updated 9 years ago by Anonymous.
  • #6068
    I have run my HECRAS model with 2D geometry. I could not find the stream flow values (CFS) near buildings, culverts and bridges. The RAS Mapper output result options include velocities, depths, WSE, but no maximum flows. Culverts and bridges are modeled as SA/2D area connections.
    Any suggestions to show “flow values” within the 2D area?
    #9874
    Lonnie A
    You can use a internal storage area connector to be able to read flow across it. Other than this there isn’t the ability to display flows in the 2D.
    Chris has a post that explains this.
    http://hecrasmodel.blogspot.com/2015/09/transect-for-extracting-flow-in-2d-area.html
    #9875
    Joe S.
    Okay, that makes sense now with the link. could not find it in my blog search. thank you for explaining.
    #9876
    Joe S.
    I am new to posting comments. I had gone to the thread you recommended. very helpful. I tried to add a comment there, but not sure if it will be read.
    my post was…….
    I have added a few SA/SD locations within my 2D geometry, as instructed above. After I save geometry, and compute. the program freezes during Geoemtry Processing. There error in red says “review your data at this location (ie the SA/SD location) for completeness and consistency”.
    #9877
    Lonnie A
    It looks like an error with the 34895 lateral and not your internal connector. When you added the internal it probably revised the mesh around your lateral?
