Welcome to the RAS Solution Forums HEC-RAS Help Flow settings at junctions
  • This topic has 1 reply, 881 voices, and was last updated 11 years ago by Anonymous.
  • #5500
    I have a reach (7-1) which receives flows from a Junction “B” (which splits flows from an upstream reach (1-1)). Reach 7-1 has a lateral weir and combines at a Junction C downstream. Junction C combines flows from Reach 7-1 and another reach and sends them to Reach 2-3. Junction B is optimized. In my model, the combined flow below Junction C determined by HECRas does not equal the combined flows entering the junction. What should be the flow value set for the beginning of Reach 2-3?
    #8777
    Keymaster
    Sounds like a fairly complex system. I recommend running in unsteady flow. The split flow optimization works ok for simple flow splits, but when you model gets complex, it’s harder to optimize in steady flow. Unsteady flow automatically optimizes.
