Welcome to the RAS Solution Forums HEC-RAS Help flow optimization failed to converge (steady flow simulation)
  • This topic has 1 reply, 1,443 voices, and was last updated 11 years ago by Anonymous.
  • #5733
    Hi
    Sir I am doing MS in RSGIS from Pakistan, and doing research on 2010 floods in Pakistan.
    Topic of my research is “Flood inundation in northern Sind during floods” A Case Study of Levee Breach Induced Catastrophic Flooding.
    I want to use Steady flow simulation for this,I was able to get split flow from the levee breach before I added Junctions and connected the reaches… now steady flow simulation gives error.
    “flow optimization failed to converge”
    Regards.
    #9175
    You’ve got split flow optimization turned on, which is good, however, RAS is not able to converge on the flow distribution within the number of allowed iterations (30 by default, 60 max…I think). You can try to up the max number of iterations for split flow, or adjust your initial “guess” at the split flow. There are many other things that can affect this. Check all of the geometry inputs, especially in the area of the split and downstream for errors. Make sure you have enough cross sections. If you’re losing a lot of flow through the breach, optimizing on the flow split could be difficult to do.
    Also, why are you not doing this in unsteady flow? A levee breach is typically done in unsteady flow because of the significant attenuation impacts of the off-channel storage, as well as the dynamic (i.e. changing over time) nature of a dam or levee breach. Unsteady flow will also do a better job of determining the flow splits.
