Do you have any nearby gages that have hydrograph data? If so you could just pick representative event and use a multiplier for your peak flows.
Are there any studies of nearby streams that have a hydrograph? You could use that with a multiplier.
You could also just create a single basin hydrology model and calibrate the lag time and CN value to match your peak flow.
you could also just run the 2D model with a constant flow of your peak and simulate a “Steady State” scenario.
