Welcome to the RAS Solution Forums HEC-RAS Help Flow dividing among 2 branches and joining downstream
  • This topic has 2 replies, 1,000 voices, and was last updated 8 years ago by Anonymous.
  • #6657
    Hallo.
    I wonder if it is possible to properly modelling with HEC-RAS the flow on a river which splits in 2 branches (different lenghts and bottom profiles) which joint in a downstream section. I need to evaluate flow conditions on each branch (reach). If I consider cross sections that include both reaches, the river bed condition seem to be predominantly, so that running the model, in some reach sections no flow occurs, weather all flow is running in the other reach: and this is not true. What do you suggest to model it correctly? Thank you in advance
    #10956
    ldguethle
    Yes it is possible to model this situation.
    If performing steady state, you can use Split Flow Optimization to help define the % of flow for each reach. Personally I would use unsteady state if that’s an option.
    Make sure you have junction lengths and cross-section layouts done properly or you will get poor results. Also check whether you have overflow between reaches (between junctions) and if so, you may need to add lateral structures.
    #10957
    I had the same task. I had to model a stream which had a bypass channel running parallel to the stream approx 100 feet away. I had to model two culverts, one in the main channel, and one in the bypass. First I tried to model it with two streams and split flow optimization, but i lacked sufficient survey information to develop accurate upstream and downstream cross section. I then noticed that the ground surface elevation between the two streams is less than the high water for the storm profiles i was designing for. So it seems like it was more appropriate to do one wide stream with two stream openings and two culverts. Fortunately i had enough survey information near the culverts to develop a local very wide model of the two streams together.
    This is just my situation. The only advice i can offer is to consider treating it as one large stream if they are close and the ground surface elevation between them is lower than your water surface elevation.
    I’ve got the split flow model if you want to take a look, however i can’t claim it is even close to accurate or correct due to the lack of survey data.
