Welcome to the RAS Solution Forums HEC-RAS Help Floodway analysis using HEC-RAD 2D for FEMA Project
  • This topic has 2 replies, 150 voices, and was last updated 6 years ago by Anonymous.
  • #7433
    HEC-RAS Models,
    I would like to use HEC-RAD 2D for a floodplain analysis which will include eventually a CLOMR to be submitted to FEMA.
    Any share experience on floodway analysis: equal convenience reduction requirement and a maximum allowable surcharge limit 1 foot for example.
    Thank for your guidance.
    Nan
    #12497
    you currently cannot do a floodway in 2D. What you can do is create a 1D model that is calibrated to the 2D and create the floodway in the calibrated model. I have also done 1D/2D models where the floodway is only in the 1D section.
    #12498
    Cameron,
    Thank you for comments.
    The reason why I am contemplating the 2D is because I have culverts, underground culverts (below buildings and parking areas), parallel railroad bridges, and split flows, which make a 1D model difficult.
    Nan
