Welcome to the RAS Solution › Forums › HEC-RAS Help › Finite Volume Approximations
  • #6721
    robdir
    Pagg.2.63-2.64 of Hydraulic Reference Manual are referred to the finite volume approach.
    1)In the description at pag. 2.63 is mentioned the “gradient term ad a grid face”…
    Which is the grid corresponding to? The blue grid or the red grid?
    I suppose the blue…
    And what about the face? The highlighted in the figure?
    2)at pag.2.64 is introduced the equation 2-148 where “the sum is over all cells around the calculation face…”
    which are the cells to consider?
    Regarding the dual area (A’), if I consider the face highlighted in the first figure, the area is calculated adding the two regions inside the two dual cells?
    Thanks to everybody wants to explain me.
