Welcome to the RAS Solution › Forums › HEC-RAS Help › Extracting Raw data from 2-D outputs
- This topic has 2 replies, 253 voices, and was last updated 10 years, 7 months ago by Anonymous.
August 26, 2015 at 4:30 am #5861AnonymousGuest
Does anyone know if there is a way to extract raw data from 2-D outputs (preferrably in some csv or similar format)? When I use RAS Mapper to create a raster it appears that some data is lost in the interpolation process as the resolution is not nearly as good as what is seen in RAS Mapper. Any help would be greatly appreciated.
Thank you ahead of time!August 26, 2015 at 7:05 am #9476Chris G.KeymasterReturn-Path:
Received: from mail-pa0-f42.google.com (mail-pa0-f42.google.com [209.85.220.42])
by mwork.nabble.com (Postfix) with ESMTP id DFD3B2721969
for; Tue, 25 Aug 2015 19:05:35 -0700 (PDT)
Received: by pabzx8 with SMTP id zx8so52219663pab.1
for; Tue, 25 Aug 2015 19:05:05 -0700 (PDT)
d=gmail.com; s=20120113;
bh=I3FAki9N1EdqK8xlObpgZTUueqLFLRq2iJfPImk7fyo=;
b=Zdq6ziZdOO0ClGA/K1qrte8UOeLdLyqATsyP10c7qACDl/DHYFinD0SyoNUgv3rgDz
rIZnG5RPV3uBCLwypkNJWHUmmraC5biDCIEJ5EtBpZTHns6C9xBCCNUQZA5hloX2JrP+
arh06Gj9fAzjp2/m4dTL7/wiLzih023eoL8iiNpmkk5/WdeHIMqVTzMOXgqgKdaD1n/q
/ysYjmk1i+Aigs5qA9oWhONgwyHlAejdVMpcagcOjOPMuj1vm1u58otqSo8ObfECclTx
C50GNSrnjbODMa/mB6RnnGkA34MawNojuQsC5OD9jByYnMxOD/JoM0DOKHGCJJ0bBS2M
X7AA==
X-Received: by 10.66.150.66 with SMTP id ug2mr24586888pab.4.1440554705298;
Received: from ?IPv6:2600:100f:b114:74ba:cd31:1b3:e732:318c? ([2600:100f:b114:74ba:cd31:1b3:e732:318c])
by smtp.gmail.com with ESMTPSA id kr1sm22511127pbc.93.2015.08.25.19.05.04
for
Tue, 25 Aug 2015 19:05:04 -0700 (PDT)
Subject: Re: Extracting Raw data from 2-D outputs
boundary=Apple-Mail-3006F9BE-1151-4D90-AB40-C76C99488211
X-Mailer: iPhone Mail (12D508)
Date: Tue, 25 Aug 2015 19:05:02 -0700
To: “PeterB [via HEC-RAS Help]”
Mime-Version: 1.0 (1.0)–Apple-Mail-3006F9BE-1151-4D90-AB40-C76C99488211
Content-Type: text/plain;
charset=us-ascii
Content-Transfer-Encoding: quoted-printableThe raw 2D data is all stored in the p##.hdf file. You can view the data and=
extract the data from a free program called HDFView. Google it to download.=
=20Sent from my iPhone
> On Aug 25, 2015, at 16:30, PeterB [via HEC-RAS Help]
wrote:
>=20
> Does anyone know if there is a way to extract raw data from 2-D outputs (p=
referrably in some csv or similar format)? When I use RAS Mapper to create a=
raster it appears that some data is lost in the interpolation process as th=
e resolution is not nearly as good as what is seen in RAS Mapper. Any help w=
ould be greatly appreciated.=20
> Thank you ahead of time!=20
>=20
elow:
> http://hec-ras-help.1091112.n5.nabble.com/Extracting-Raw-data-from-2-D-out=
puts-tp1932.html
> NAML–Apple-Mail-3006F9BE-1151-4D90-AB40-C76C99488211
Content-Type: text/html;
charset=utf-8
Content-Transfer-Encoding: 7bitThe raw 2D data is all stored in the p##.hdf file. You can view the data and extract the data from a free program called HDFView. Google it to download.Sent from my iPhone
On Aug 25, 2015, at 16:30, PeterB [via HEC-RAS Help] <[email protected]> wrote:Does anyone know if there is a way to extract raw data from 2-D outputs (preferrably in some csv or similar format)? When I use RAS Mapper to create a raster it appears that some data is lost in the interpolation process as the resolution is not nearly as good as what is seen in RAS Mapper. Any help would be greatly appreciated.
If you reply to this email, your message will be added to the discussion below:http://hec-ras-help.1091112.n5.nabble.com/Extracting-Raw-data-from-2-D-outputs-tp1932.html
NAML
–Apple-Mail-3006F9BE-1151-4D90-AB40-C76C99488211–August 27, 2015 at 2:31 am #9477AnonymousGuestThat worked great. Thank you
