Welcome to the RAS Solution Forums HEC-RAS Help extracting manning’s n to cross sections from ras mapper- is it possible?
  • This topic has 1 reply, 597 voices, and was last updated 9 years ago by Anonymous.
  • #6263
    Now that we can import lanudse files into ras mapper, is there a way to extract mannings’s n at each cross section from the landuse map that we import into ras mapper?
    i extracted cross sections from hecgeoras. For some reason, my cross section looked different from the the undelying terrain. So in HEC-RAS 5.0.3, i used the “cut from terrain” option in geometry editor to update the elevations. In this process, i lost information on the ‘n’ values for the cross sections. Is there a way to retrieve it in HEC-RAS itself.
    Kindly help me on this one.
    Bharath
    #10204
    Not currently that I am aware of. Since the cutline lengths are not going to change, you could just import in the data from GeoRAS to the geometry and only select the n values to import (not the terrain).
