Welcome to the RAS Solution Forums HEC-RAS Help extract velocity from hdf file using matlab
  • This topic has 2 replies, 102 voices, and was last updated 6 years ago by Ping.
  • #7646
    Ping
    I run the 2D unsteady flow simulation, the results are saved in the hdf file. I want to extract the velocity and water surface from the hdf file using matlab, because I want to further analyze the data in matlab. How can I extract the velocity and water surface in matlab? has anyone done this ?
    Thanks a lot for help.
    #12772
    Sure!
    Try this function: h5read, you can find information about it in matlab help assistant.
    You will have to define some atributes.
    regards,
    Antonio
    #12773
    Ping
    Dear aruiz,
    thank you, the data structure in hdf file is a bit complex, it needs to arrange it into 2D coordinate, I have made it. thanks
