Welcome to the RAS Solution Forums HEC-RAS Help Exporting georeferenced WSE results to CSV file
  • This topic has 1 reply, 103 voices, and was last updated 6 years ago by DH.
  • #7421
    DH
    Hello everyone,
    Is there an easy way to export the water surface elevation computed at each cross section in my 1D model to a CSV file?
    I want a CSV file with the cross section number, easting and northing values for the lowest XS point, and the corresponding WSE. In other words, a summary of WSE at points along the thalweg.
    I have viewed the summary output tables but they do not seem to include columns for x and y locations.
    Thank you!
    Duncan
    #12482
    gerardo
    Hello, I write in my native language, Spanish. In the end it is translated into English
    Debes ir a “geometric data” luego a “GIS Tools” luego a “XS cut line table”
    Ahí obtienes las coordenadas de la recta XS
    Con ellas calculas la forma Y=aX+b para cada XS
    En las tablas de resultados debes generar una que de lo siguiente “Sta W.S. Lft” y “Sta W.S. Rgt”
    Luego con matemática básica calculas las coordenadas de los límites izquierdos y derechos del agua
    Yo uso excel
    You must go to “geometric data” then to “GIS Tools” then to “XS cut line table”
    There you get the coordinates of the XS line
    With them you calculate the form Y = aX + b for each XS
    In the results tables you must generate one of the following “Sta W.S. Lft ”and“ Sta W.S. Rgt ”
    Then with basic mathematics you calculate the coordinates of the left and right limits of the water
    I use excel
