I’ve found that you can create rasters of the mapping. This is how I did it:
1)select the floodplain mapping check box in the unsteady flow analysis window
2)After running model open RAS Mapper, tools, manage results map, select the plan results for the plan you want in the view results maps pulldown, select add new map then in that window pick elevation, maximum, the stored raster button and “create this map”, then back at the manage resulst map you may need to select the “elevation (max)” line and then hit “compute/update stored maps”. If the line has a icon by it it should of been created and is stored in your model location folder.
I’ve tried the stored polygon (zero depth boundary) using both depth and elevation along with maximum hoping to get a polygon but didn’t have any luck.
