Welcome to the RAS Solution › Forums › HEC-RAS Help › Export of table: time vs. velocity
Hi
I was solving dam breach analysis and I need help.
Can I export a result table (time vs. velocity) for inline structure (IS) using interface of hec-ras or DSS?
thank you very much regards! Robert
I don’t believe you can directly. But if you set the detailed output interval to the time steps you want you can use the inline structure table and add weir flow area to it. Then in excel simply divide Q weir by the weir flow area.
Please enter an answer in digits:
