Welcome to the RAS Solution › Forums › HEC-RAS Help › export D*V map
- This topic has 2 replies, 126 voices, and was last updated 6 years, 7 months ago by hasansins.
August 29, 2019 at 4:20 am #7420hasansinsParticipant
Hi everyone. i just exported D*V map and got the .tif files along with a .vrt file.
I can not seem to import these in to autocad. Is there anyone who were able to successfully import D*V map in to cad?
August 30, 2019 at 6:20 am #12480alister.hoodParticipantReturn-Path:
by sloti1d2t14 (Cyrus 3.1.7-154-gfa7592a-fmstable-20190829v1) with LMTPA;
Thu, 29 Aug 2019 22:20:57 -0400
X-Cyrus-Session-Id: sloti1d2t14-1567131657-3214089-2-5915104737689049197
X-Sieve: CMU Sieve 3.0
X-Spam-known-sender: no
X-Spam-score: 0.0
X-Spam-hits: FREEMAIL_FROM 0.001, HTML_MESSAGE 0.001, RCVD_IN_DNSWL_NONE -0.0001,
SPF_HELO_NONE 0.001, SPF_PASS -0.001, LANGUAGES en, BAYES_USED none,
SA_VERSION 3.4.2
X-Spam-source: IP=’209.85.208.172′, Host=’mail-lj1-f172.google.com’, Country=’US’,
by compute1.internal (LMTPProxy); Thu, 29 Aug 2019 22:20:57 -0400
by mailmx.nyi.internal (Postfix) with ESMTP id 3A7473C02FD
for; Thu, 29 Aug 2019 22:20:57 -0400 (EDT)
id 90105DCA57E;
1567131657; b=bpXQ5zLfQeNehGRQHV+xuUbOWkNZDRjplUd6B5gke2FOTM48bE
d8uufMcILKRKJ8IUI8h6X0xPR2mIcX2fzw/V/baEAYabfwsbopIqQOLqkQNg3+sy
UyR2c71yMCpA3tDP1gZf5mt6eo4AmTuP8vUlwmrPfcSnOstthAi16lka1lPEKKVD
3rHstKLQCmuXTESqcZ4tgVukJurkCXqYE+ykabnpViCqAWiPiEuKRn04KgyiXq8a
NZcEggr0a8WcW2lbTwEg3QG2pQDurlhzd8fTdlpLtgb+J6ZOm2QZ9BylCcoexcTn
eMfzUafSFt42YpSzxNhYAXz6AtDmnuQoHRjw==
:date:message-id:subject:to:content-type; s=fm3; t=1567131657;
bh=ChitUSflv4plwH2VgB6Xp6mOw7Zi9Si2PAboj/y6oJo=; b=gG9xtBneClCc
fuh3bEZkI7oYaCEcFV18z/IfYkpLnW5EZk9Yc9iaidsZhHJPBPvJi+Wixrx1VTyC
Hx/es4FrlzQ/uwPAKqvhAYGe1kFrDEuZRGy2zX6KY+9+dKhSwByosFX1Iis8m12H
BQ7yQOgjuTdcJMq7LNh+mPYz4nskyaelEWtU34NTWQuK3hctKSWYpA2xdftGjQBV
I6ZRSJKzFCSAFggV2PbHDF7oytb9wf1J6hdvTs9MnDsFpMZSjmWz2zo0Md7QAeZw
ocLE8i1ULkLmkIKnVay0RIp2+PGKaVlo2g8yZaaqt19f5NOX2mr6Y2cPEXIQiguR
BwGT4uqpLQ==
[email protected] header.b=W8cufg/y header.a=rsa-sha256
header.from=gmail.com;
iprev=pass smtp.remote-ip=209.85.208.172 (mail-lj1-f172.google.com);
spf=pass [email protected]
smtp.helo=mail-lj1-f172.google.com;
[email protected] header.b=nBOzPlNt;
x-ptr=pass smtp.helo=mail-lj1-f172.google.com
policy.ptr=mail-lj1-f172.google.com;
(MX Records found: alt3.gmail-smtp-in.l.google.com,alt2.gmail-smtp-in.l.google.com,alt1.gmail-smtp-in.l.google.com,gmail-smtp-in.l.google.com,alt4.gmail-smtp-in.l.google.com);
smtp.bits=128/128;
x-vs=clean score=0 state=0
smtp.bits=128/128;
X-ME-VSCause: gggruggvucftvghtrhhoucdtuddrgeduvddrudeifedgheegucetufdoteggodetrfdotf
fvucfrrhhofhhilhgvmecuhfgrshhtofgrihhlpdggtfgfnhhsuhgsshgtrhhisggvpdfu
rfetoffkrfgpnffqhgenuceurghilhhouhhtmecufedttdenucenucfjughrpeggfhgjhf
ffkffuvfgtsegrtderredttdejnecuhfhrohhmpeetlhhishhtvghrucfjohhougcuoegr
lhhishhtvghrrdhhohhougesghhmrghilhdrtghomheqnecukfhppedvtdelrdekhedrvd
dtkedrudejvdenucfrrghrrghmpehinhgvthepvddtledrkeehrddvtdekrddujedvpdhh
vghlohepmhgrihhlqdhljhduqdhfudejvddrghhoohhglhgvrdgtohhmpdhmrghilhhfrh
homhepoegrlhhishhtvghrrdhhohhougesghhmrghilhdrtghomhequcfukfgkgfepgeei
hedtnecuvehluhhsthgvrhfuihiivgeptd
X-ME-VSScore: 0
X-ME-VSCategory: clean
Received-SPF: pass
identity=mailfrom;
client-ip=209.85.208.172
Received: from mail-lj1-f172.google.com (mail-lj1-f172.google.com [209.85.208.172])
for; Thu, 29 Aug 2019 22:20:56 -0400 (EDT)
Received: by mail-lj1-f172.google.com with SMTP id x18so4989034ljh.1
for; Thu, 29 Aug 2019 19:20:56 -0700 (PDT)
d=gmail.com; s=20161025;
b=W8cufg/yZxbu0nfZvou4ZLD/iZCPtsCJ0rbb6jbBZl8VXFk0j7kqUjW6APnVHyzRT2
NG32AdgmPQSshtkUPExwqf6q4zenVVqFJ4l5+ZL6wxnHmMDKQ/B5Miszcb+lzGx26T6O
6o8PsjM5z2Cd/M45n+beeX5McNp8aepiQGdeNUDLfhyoxBcpjrsWrXm9EVhh8nSEoNmp
iNTpIAIPtzIfjqFtVOfy/U4q2K/WNVJPd7gLl6jj1gfrSoGU1dPppwpCcwCNVOq5wo9l
9Yu7EwCLiDbjH8a90hL9RN/ntC2E3Q2GXbDke0e/O88N1/7u1/53Lk/JNdHS+Inc4N3G
2s2g==
d=1e100.net; s=20161025;
b=nBOzPlNtjg1fpxWktvFzqbdKFusMzx1ttiG+nyvp9fnIHG3YcN0jTS26go3GKL/sCf
w6xnx5DRwBfz9gXq4JLR6u4xtBffmUWLqv/Vx1Spdqea95m5ysclIMobThYT9MUNfChs
9I5d6+MYlzhpf5QnFzbuvM5mZxIAUKd/pXj1aw7XAecLOjB9be0ok1rnpqSHBREt80uD
vBibMMN/fM8pKiS1ogZH9P5tlwnwwpS2CtgDRbaZrCDU3HT5jAfG6S4QQGkXerCH8Nb8
ygqWo81eJDQiBr5hbZQ8W5PRU7NJBafAr99ol/1e19xOKfhd2dXuvrqGqv0jtI8npEqN
byGw==
X-Gm-Message-State: APjAAAW5m0lafeoKurFsPT/b7qJA6JLxovW4bU8VXhMSddtn0PndR9fJ
27hdaCFGJgYTSuazUir7MoSZf80x8b15lthpzlTpgw==
X-Google-Smtp-Source: APXvYqx2btQyWCzsmoBX7GtibmyP9lsIH8KwIDO0JJ3Upr1oirlWh/IvWILf7ijV+7liqX7CgVQNSVFS2v4AKsH8XQk=
X-Received: by 2002:a2e:a313:: with SMTP id l19mr7288174lje.32.1567131654527;
Thu, 29 Aug 2019 19:20:54 -0700 (PDT)
MIME-Version: 1.0
Date: Fri, 30 Aug 2019 14:20:39 +1200
Message-ID:
Subject: Re: export D*V map
To: “hasansins [via HEC-RAS Help]”
Content-Type: multipart/alternative; boundary=”000000000000959ef105914c45bd”–000000000000959ef105914c45bd
Content-Type: text/plain; charset=”UTF-8″Hi,
It is a single band raster storing the value of V*D. I can’t remember
trying to load a single band raster into AutoCAD, but even if it works it
might just look all black or all white. You will want to control the
styling, probably using colour, perhaps to mimic how it looks in HEC-RAS.I guess if by “AutoCAD” you mean Map3D then that can do it. But if you mean
normal AutoCAD you will need to style it in you favourite desktop GIS (I
recommend QGIS) and export a rendered image.If you style it in QGIS, just do “Layer>Save As”, select “Rendered image”
and save as tiff or jpeg.
If you save as tiff, make sure to add a create option called “TFW”, with
value “YES”.
Once you have loaded the image into AutoCAD you can use the freeware
utility called georefimg, which reads the worldfile and moves the image to
the correct location and scale.Regards.
Content-Transfer-Encoding: quoted-printableHi,It is a sing=
le band raster storing the value of V*D. I can't remember trying to loa=
d a single band raster into AutoCAD, but even if it works it might just loo=
k all black or all white. You will want to control the styling, probably us=
ing colour, perhaps to mimic how it looks in HEC-RAS.I guess if by "AutoCAD" you mean Ma=
p3D then that can do it. But if you mean normal AutoCAD you will need to s=
tyle it in you favourite desktop GIS (I recommend QGIS) and export a render=
ed image.If you style i=
t in QGIS, just do "Layer>Save As", select "Rendered imag=
e" and save as tiff or jpeg.If you save as tif=
f, make sure to add a create option called "TFW", with value &quo=
t;YES".Once you have loaded the image into Aut=
oCAD you can use the freeware utility called georefimg, which reads the wor=
ldfile and moves the image to the correct location and scale.Regards.–000000000000959ef105914c45bd–
September 15, 2019 at 5:28 am #12481hasansinsParticipantThank you for explanation.
