Welcome to the RAS Solution Forums HEC-RAS Help Excavation increases Water Surface!
  • #5678
    dueckrandy
    Hello, I am running very large model for a river system in an urban area. I am modelling the effects of a relatively small amount of fill in the floodplain. When run, this causes 0.00′ of rise in WSEL. However, when I add an excavation of about the same size, and decrease the n-value (both of which normally reduce WSEL), I get a WSEL increase of 0.01′! Any idea why this happens and how to remedy it?
    Thanks!
    #9080
    Did you ever find the problem/solution? i am experiencing the same problem right now
    #9082
    Upload screen shots. Is this 2D?1D? Unsteady? Steady?
    #9081
    This happens all the time when you open up the channel. The velocities most likely reduced which causes the wse to increase.
