Welcome to the RAS Solution Forums HEC-RAS Help Errors in storage area(banks layer) is creating steady flow
  • This topic has 3 replies, 1,822 voices, and was last updated 12 years ago by Anonymous.
  • #5271
    Hello all, I’m a new user in HEC-RAS
    I’m trying to make a steady flow data and the goal is to have flood inundation maps in arcgis 10.1. The problem came when I set up steady flow data in HEC-RAS 4.1.0 the message says: “HEC-RAS Error – Incomplete data, the following errors were found:
    Connection: 679
    The “start” part of the connection must reference a storage area or cross section.
    The “end” part of the connection must reference a storage area or cross section.
    Connection: 680
    Connection: 681
    – There are no flow values in the steady flow data.”
    What can I do to fix this?
    thank you
    #8383
    Keymaster
    sounds like you have storage area connections that are not fully connected. Go to the geometry window, click on the storage area connections button, and then make sure that each storage area connection you have is connected on both it’s upstream and downstream sides to either a storage area or a cross section. Hope this helps.
    #8384
    i have the same problem when i am trying to compute steady flow analysis the program give me error :
    but i do not have any storage area . would u please help me if possible ?
    #8385
    I would go into the “Connections” prompt located just below the “Description” prompt and reassign the connections again.
