Welcome to the RAS Solution Forums HEC-RAS Help error XS in RasMapper
  • #15236
    mat A.
    Hello, I vant to create a new geometry in Rasmapper :
    – i import a river shp
    – i import cross sections with z attribute
    My problem is : all cross sections are false : there is a “shifting” of two z values, or there are new points created!
    If i import good points in elevation point layer, to interpolate xs, a new problem : new points are created!
    Has someone ever had this problem? Thanks in advance
    Regards!
    #15237
    mat A.
    for example, here is my profile 1:
    0 39.3
    1.722648 37.1
    3.927871 36.93
    6.111168 39.3
    here is my profile 1 imported with rasmapper :
    0 36.93
    1.722648 39.3
    3.927871 39.3
    6.111168 37.1
    here is my profile 1 interpolated with elevation point layer :
    0 36.89
    2.375541 38.34
    2.933068 38.24
    4.698927 41.96
    x values are ok but z values are false
    #15238
    mat A.
    sorry if i interpolate my profil 1 with elevation point layer result is there :
    0 36.89
    1.722648 37.1
    3.417569 36.78
    3.927871 36.93
    4.346167 36.82
    4.76373 37
    6.111168 38.12
    3 points are created and only two points are ok with z, the others are false
