Welcome to the RAS Solution Forums HEC-RAS Help Error writing sediment boundary conditions to HDF file
  • #15227
    Hannah May
    I am trying to model a quasi unsteady flow with sediment. I have a working geometry calibrated for steady flow. I cannot run the model with a quasi unsteady flow and sediment data. I have tried to make the input data as simple as possible to deal with the error. I am getting the following 2 errors:
    1. Error writing sediment boundary conditions to HDF file.
    2. Run-time error ’91’: Object variable or With block variable not set.
    And then the program crashes.
    Has anyone had this issue? Any ideas on what is happening or how I can fix it?
    Thank you!
