Welcome to the RAS Solution Forums HEC-RAS Help Error with Muncie 2D example
  • This topic has 0 replies, 198 voices, and was last updated 8 years ago by Anonymous.
  • #6812
    I am simply trying to run the the given example “Muncie” in HEC -RAS 5.0.3. I have not changed anything but it still stops during the unsteady flow simulation. Here is the error. Sometimes when I adjust the computational time step, it’ll run slightly longer before stopping and I’ll get an exit code 168. I have searched the forum and online and cannot find the answer to this problem. I would appreciate any help!
    Plan: ‘try4’ (Muncie.p07)
    Simulation started at: 08Mar2018 08:53:50 AM
    Using 64 Bit Computation Engines
    Writing Geometry
    2D Interior Area: Mesh property tables are current.
    Completed Writing Geometry
    Geometric Preprocessor HEC-RAS 5.0.3 September 2016
    Finished Processing Geometry
    Writing Event Conditions
    Event Conditions Complete
    Error with program: RasUnsteady64.exe Exit Code = -1073741795
    Computations Summary
    Completing Geometry 1
    Preprocessing Geometry(64) <1
    Unsteady Flow Computations(64) 7
    Complete Process 9
