Welcome to the RAS Solution Forums HEC-RAS Help error when run program in computational window
  • #5509
    I have huge problem ,i try to solve it many times but I cant
    it appear red color inmcomputational window may the cause is cross sections because i dont know when put levees and
    In effctive aread
    Ihope help me
    thanks
    #8792
    Perhaps the initial conditions that you have specified (flow and boundary conditions) result in zero depth somewhere in your reach. The RAS unsteady flow solution will not work with zero depths at any computational cross sections. Suggest that you run your model with steady flow (using the initial flow in your unsteady flow data) to check the depths. Another possibility is the occurrence of supercritical flow; that may cause the computations to abort. So, check the channel slope and initial flows for this condition.
