Welcome to the RAS Solution Forums HEC-RAS Help Error starting process: Ras Geom Writer
  • #6252
    Wojciech
    Hello
    I have a problem running the calculations. I have prepared a model that works in version 4.1.0.
    The same model loaded in version 5.0.3 of the RAS prepared Mapper area does not work. Error pops up as below
    In Geometries RAS Mapper – XS
    pops up the error:
    “Error reading features from file: ‘C: \ Documents adn Settings …. \ name.g .hdf’ group: ‘Geometry / Cross Sections’ H5O.getInfoByName: Object ID: 1000000 failed to return object information with status -1 .
    What could be wrong?
    #10176
    Wojciech
    I solved the problem. The HEC RAS ​​order is important work. To firstly need to create geometry in the Geometric Data. Later in Ras Mapper creating access area.
    Best regards.
    Wojciech
    #10177
    I’m getting this same message as Wojciech when trying to start unsteady modeling computations. The same model yesterday worked just fine. I tried closing and restarting the model but that didn’t fix the problem. Unlike Wojciech, I haven’t done anything in Ras Mapper.
    #10178
    OK, I figured out my own problem. Apparently I reached the memory limit of our server. I was not able to save additional files to the network. After deleting several large *.bco files I was able to run the model
    #10179
    ReneeB
    I received the same message. Can you describe how you made this error go away?
    #10180
    I’m getting the same error after modifying a geometry file and trying to run a steady flow analysis. Any ideas? What’s strange to me is that if I import the same geometry file and call it something else, the model runs just fine.
    Thanks for your help!
    Erin W
    #10181
    did you get this issue with the RasGeomWriter resolved?
