Welcome to the RAS Solution Forums HEC-RAS Help error post processor unsteady flow
  • #7340
    santipau
    I’m having a problem modelling unsteady flow.
    It gives me the next error
    Error running the unsteady post processor: cañada rosario
    DSS File used: C:\Users\Santiago Pauletti\Google Drive\SINGE Uruguay\2019 – Rosario –
    Linacqua\modelo\HEC-RAS\cañadarosario.dss
    Error reading data from path: /CAÑADA TRAMO1//LOCATION-FLOW//MAX STAGE/PLAN 04/ Path not found.
    Thanks in advance
    #12321
    Sarath
    hi, I am facing the same problem , were you able to solve it, if yes how?
    #12322
    Jarvus
    RAS has problems with characters that are not part of the American standard such as the “ñ” in cañada.
    Avoiding these characters if using RAS is recommended. I know that some people have switch their Windows operating system to English (American) to try and deal with it.
    #12323
    Rodrigo Urquiza
    Hey Santi, you shouldn’t use “ñ” or written accents in any word in the path. Also you should keep the path as short as possible.
