Welcome to the RAS Solution Forums HEC-RAS Help error = Index was out of range
  • This topic has 5 replies, 1,323 voices, and was last updated 9 years ago by Anonymous.
  • #6347
    Just trying to figure out how to solve the below error that comes up when I try to complete steady flow analysis. Any help would be appreciated.
    “Writing Geometry
    Computing XS Interpolation Surfaces
    Error generating interpolation surface
    Error creating TIN for region between XS’s:
    River: Lucky Creek Reach: Reach 1 River Station: 530
    River: Lucky Creek Reach: Reach 1 River Station: 510
    error = Index was out of range. Must be non-negative and less than the size of the collection.
    Parameter name: index”
    Cheers!
    #10385
    Do the cross-sections overlap or is there a big difference between how wide the cross-sections are at that location?
    #10386
    anandtkulkarni
    Hi Luke
    Did you get solution over it?
    I am facing similar error in writing geometry
    Regards,
    Anand K
    #10387
    xiangang
    Hey Luke,
    Did you get the issue solved? I got the exactly the same error messages
    It’s likely your working folder has previous files and that probably the reason to cause the problem.
    Clear the working folder first and re-generate the RAS files, it will solve the problem.
    #10388
    hey luke did u get any solution ?
    #10389
    set bank stations to 10-year and re-run, it should resolve the issue.
