Welcome to the RAS Solution Forums HEC-RAS Help Error in Running Hec-RAS 5.0.5
  • This topic has 1 reply, 285 voices, and was last updated 7 years ago by BO2.
  • #7066
    BO2
    Dear all
    I have been setting up different models in a Norwegian river using a large Green LiDAR dataset with a very high point density (up to 30 points pr m2) for making accurate DEMs as input to the model.
    The models run fine on my LAptop (ZBook 15 G3, Xeon E3-1505M 2.8 GHz, 32GB RAM, NVIDIA M2000M graphics card). But as the models are quite large and can take between 2 and 32 hours to run, I would like to use a dedicated computer for running the simulations.
    I have access to a computer running Windows Server 2016 (i9 7900X 3.3 Ghz, 128 GB RAM), but I keep running int errors using this machine.
    Is it not possible to run HEC -RAS on a server? The latest error code was:
    Error with program: RasUnsteady64.exe Exit Code = -1073741819
    Thansk for any help
    Bjørn Otto Dønnum
    #11794
    ckatsoulas
    The only time I got this type of error code is when I used the variable time step option and my starting time step was too high. Try using the fixed time step or change starting time step with a low time interval.
