Welcome to the RAS Solution Forums HEC-RAS Help error in 2D (adding Manning’s Table)
  • #6789
    sanjeewa
    Dear Friends,
    I have problem in 2D ” property tables do not exist”
    I created 1D/ 2D model and I added relevant Manning table (shape file, Land cover) file and updated under edit land cover to Manning’s n. Then I try to simulation model, but it gave property tables do not exist.
    I would be grateful for comments and solutions to solve this problems,
    thanks
    Kind regards,
    Sanjeewa
    #11198
    Each grid cell has to have their property tables calculated before running the model for the first time. If any changes are made to the mesh, the tables need to be updated and will do so when you try to run it again.
    #11199
    Thank you Dear Friend.
    Above message initially – “computing 2D flow area table 8 Property table do not exist”
    After that “2D flow area 8 table complete”
    Is that mean geometry ok or not.
    sanjeewa
