Welcome to the RAS Solution Forums HEC-RAS Help Error generating edge lines
  • This topic has 1 reply, 962 voices, and was last updated 8 years ago by Anonymous.
  • #6801
    If I run my Modell the following Error appears:
    Plan: ‘Plan 02’ (GEP_xx.p02)
    Simulation started at: 02Mrz2018 11:37:46 AM
    Using 64 Bit Computation Engines
    Writing Geometry
    Computing River Edge Lines
    Computations Summary
    Completing Geometry <1
    Complete Process <1
    Does anyone know what the Problem could be?
    Thank you!
    #11229
    I know it is an old thread, but maybe someone find it useful. I had a similar problem in 1D steady and unsteady flow modules (both use same preprocesor for generating edges lines).
    The problem was caused byinconsistent XS Cut lines – unsorted in my case. I was able to fix it manually (small case study) editing these lines in Geometry Editor\GIS Tools\XS Cut Lines Table. Removing the georeference from the cross sections did not work (HEC-RAS ver. 5.0.5).
    Best
