Welcome to the RAS Solution Forums HEC-RAS Help Error determining interpolated cut line
  • #16013
    VINEELA NANDAM
    When I save the geometry data (aimed to run 1D/2D coupled model), a pop-up window appears showing “Error determining interpolated cut line”. Can anybody explain what are the possible reasons for this error?
    #17633
    Mohit Jani
    In that case, you must check the reach length table and structure data tables. It might happen due to improper data feed in the geometry.
