Welcome to the RAS Solution Forums HEC-RAS Help Error- Boundary condition
  • #7314
    Nisha
    I’m setting up 1D/2D network and I’m getting following error message. Any advice to get rid of this error is really appreciated. (I have set the initial flow, minimum flow ect. I’m simulating this under unsteady flow condition)
    Regards
    Sumedha
    #12264
    It looks like you are trying to specify a flow hydrograph at the downstream end of the model. Usually a normal depth or stage hydrograph is used for downstream boundaries.
    As stated in the error you need to specify a initial wse for the boundary condition. Next to the Min Flow and Multiplier input option there is a Initial Stage box that needs information.
    #12265
    Nisha
    Thanks for your reply Cameron. Well I have assigned a stage hydrograph at the outlet. Anyway, I reconstructed the model, then it worked.
