• This topic has 5 replies, 356 voices, and was last updated 6 years ago by nour.
  • #7522
    nour
    Performing Unsteady Flow Simulation HEC-RAS 5.0.7 March 2019
    Maximum adaptive timestep = 24:00:00 Minimum adaptive timestep = 24:00:00
    Initial adaptive timestep = 24:00:00
    Subroutine HDF_SET_COMPRESSION
    #000: ..\..\src\H5Pdcpl.c line 869 in H5Pset_chunk(): all chunk dimensions must be less than 2^32
    #12606
    try reducing your time step from 24 hours, that is a little high.
    #12607
    nour
    – deleted –
    #12608
    try reducing your 1 year outputs to something smaller.
    #12609
    nour
    – deleted –
    #12610
    What is the purpose of running the model for multiple years with a constant flow rate for each year? Are you doing sediment transport?
