Welcome to the RAS Solution › Forums › HEC-RAS Help › Environment Adjustment
  • #7606
    Thomas
    Hello everyone,
    I need help with my flood modelling. When I perform a steady flow analysis, the water stays constant at the sides of the bank stations, even though it should decline. How can I make the water decline at the sides of the bank stations?
    Thank you in advance.
    #12742
    HEC-RAS calculates one water surface elevation for each cross-section. There is no way for it to have more than one.
    You would either need to do a 1D/2d model or an all 2D model to get different results in the overbanks.
