Welcome to the RAS Solution Forums HEC-RAS Help empty windows for results in hec ras 2d
  • #6982
    florence
    good day everyone! i am trying to view the results of the simulation run by selecting the View menu in HECRAS window and select the different options like Water Surface Profiles, Rating Curves, Detailed Summary Table, etc but each window that appears is empty. What could be the problem? Thank you.
    #11566
    2D results are shown in the Mapper
    #11567
    florence
    thank you cameron for your reply.
    #11568
    florence
    i am trying to view the Detailed Output Tables under the View menu in the main HEC RAS window but the table is empty.
