Welcome to the RAS Solution Forums HEC-RAS Help Displaying result in 2D
  • This topic has 3 replies, 104 voices, and was last updated 6 years ago by sam1.
  • #7485
    sam1
    In 2d models, when i display the depth result, the water starts from the upstream BC of my 2d flow area but the simulation period ends befor reaching the downstream boundary of the 2d flow area. How the time simulation should be fixed to reach a realistic representation
    #12556
    ckatsoulas
    your simulation time is too short. You’re not giving HECRAS enough time to route the flow through the terrain. Extend the simulation time until the flow reaches the outlet and empties.
    #12557
    sam1
    Thank you for your reply.
    I modified the simulation time, now the flow reaches the downstream boundary condition. On the other hand I don’t understand why when the flow reaches the downstream boundary condition the flow disappears ( or empties as you said).
    My objective is to export from hec-rass the simulated discarge near the downstream boundary condition. But at this moment, when I draw a profile at this point to export the calculated flow, there are several periods where the flow is 0 because at these periods there is no flow around the lower limit.
    Thank you for your help
    #12558
    If this is not working for you, you can try this.
    I would draw a dummy weir that is the exact same height as the terrain just upstream of your DS boundary condition. Assign the weir coefficient a 0.2 value. Run the model and then review the results at the weir. This should give you a hydrograph to take from
