Welcome to the RAS Solution Forums HEC-RAS Help display minimum flow depth
  • This topic has 1 reply, 146 voices, and was last updated 6 years ago by Wolf.
  • #7556
    Wolf
    Hi forum,
    Iam running a 2d model with rain on grid. It does well but – display of the minimum flow depth below a given threshold doesn´t work. Ras overrules …
    Because every cell has water since there is no infiltration available in this version 5.0.7 yet (I wait for the next release…;-), so every cell should have minimum flow depth around 0,001m. The map layer depth (min) shows an empty map –
    The grafic legend has a lowest value of 0,000m: layer depth(Max)
    Is there an internal parameter that controls the minimum flow depth? I couldn´t find any..
    Thank you for your suggestions…
    #12657
    ckatsoulas
    There is an option in RAS mapper you can try.
    Go to Tools>Options>Render Mode and try setting the Plot Tolerance to a number less than 0.001 which is the default.
