Welcome to the RAS Solution Forums HEC-RAS Help Different manning n values for channel bottom, walls and lid
  • #6687
    Hello people,
    I am modelling the flow (mostly steady, free flow) inside of a diversion tunnel, and would like to define different roughness coefficients for the channel bottom, the walls and the lid.
    I haven’t found a way to do this, anybody got a solution or idea?
    Thanks for any advice
    #11019
    In the geometry data editor select options and select “vertical variation in n values”
    However, this would require you to model the tunnel using cross sections with lids.
