Welcome to the RAS Solution › Forums › HEC-RAS Help › derive discharge-volume relationship from HEC-RAS for HMS modified puls routing
  • #14554
    L. J. Zhao
    In order to get discharge-volume relationship for a reach using modified puls routing in HMS, a couple of steady-state HEC-RAS runs are to be performed using different flows. For each steady state run (thus each unique discharge), does HEC-RAS output a volume between two cross sections specified? or you have to calculate it manually using end area method?
