Welcome to the RAS Solution Forums HEC-RAS Help Depth Peak at the beginning of a simple channel – 2D Modeling
  • This topic has 6 replies, 563 voices, and was last updated 8 years ago by Anonymous.
  • #6443
    Hi !
    I created a simple channel with a trapezoidal section : 150 m long ; 20 m wide ; a slope of 2 %.
    The boundary conditions are :
    – at the beginning of the channel : a flow hydrograph with a flow of 50 m3/s for 3 hours of simulation time
    – at the end of the channel : normal depth with a friction slope of 0.02
    My mesh is made of 1m-squares and I created 2 breaklines : one for each bank of my trapezoidal channel.
    After the unsteady flow computation, an element surprises me : as regards the depth for a longitudinal profile in the middle of the channel, I notice a depth peak of 0.46 m at the beginning of the channel. Then, the depth returns to a steady value of 0.28 m.
    I do not understand why I observe this peak which is not physically explicable.
    Does anyone have ideas ?
    Thank you in advance for your answers,
    #10534
    What is your timestep and what slope did you enter for the upstream boundary condition? Are you using the Full Momentum Solver?
    #10535
    gustbadell
    I am having a similar issue.
    I’m running a 2d model, diffusion wave, 2m x 2m cell, and 1m x 1 m cell on brakelines around my channel.
    The model behaves ok until peak flow comes, it seems flow spreads first towards banks and then goes downstream.
    I established normal depth for boundary condition upstream with a 0.005 m/m slope. I have tested several time steps and cell dimension configuration.
    I don´t know if th result is correct because I´m modeling a low slope to flat area with a big peak flow.
    I´d really appreciate if someone tells me what I´m doing wrong.
    #10536
    what is your timestep? If you switch to Full Momentum and the model crashes, your timestep is too high. Do you need to use a cell of 2m or can you use a larger value?
    #10537
    I am modeling a kind of small stream, when I set a bigger cell size the model tends to make the flow advance very quickly and it spreads even wider, and I have tested several timesteps, since less than a second to a half and hour, When I set the 30 minutes timestep, the flow dissapears for few timesteps, like if the flow dries due to all volume goes off towards my model outlet
    My hydrograph has a high peak flow, very big for the stream, so, It is logic to have overbank flow
    #10538
    You need to follow the Courant criteria when selecting a time step. A 30 min timestep is way to high. It should be on the order of seconds genearally and with a 2m grid it would be 1 second or smaller most likely.
    #10539
    I revised the results and I notice the depth at upstream boundary is ok. I analyzed flow spreading and realized the most of the flow is in the main channel, overbank flow is only few centimeters depth so I think the result is logic taking into account I’m modeling a mild to low slope area, draining a peak flow of 100 years return period.
    I will open a new thread to ask some questions about weir coefficients to model flow over road embankments.
    I really appreciate your help
