Welcome to the RAS Solution Forums HEC-RAS Help Depth Grids HEC-GeoRAS
  • This topic has 3 replies, 356 voices, and was last updated 10 years ago by Anonymous.
  • #5823
    I was provided a HEC-RAS prj and when I ran it with HEC-GeoRAS for depth grids it looked like this (as it should):
    http://i57.tinypic.com/14o0g43.png
    I made some modifications to cross sections to implement a floodplain bench scenario, ran a steady flow analysis and imported the results into HEC-GeoRAS again. This time the depth grid looked like this:
    http://i60.tinypic.com/2zr4aj6.png
    What might be happening between the original model and the changes I made to mess this up?
    Edit: Now that I’m thinking about it, would this have anything to do with the fact that I “excavated” certain areas and therefore changed the topography. My changes now no longer match the DEM and so it cannot produce an accurate floodplain delineation? If this is the case, is there anything I can do to remedy this?
    #9379
    If you changed the cross-section data by excavating it, you will need to modify the terrain used in Geo-RAS to match or else the floodplain may not look correct when mapping.
    #9380
    That does make sense, thank you. Is there a way to modify a DEM to fit my new cross sections?
    #9381
    In version 5.0 you can create terrain from your cross-sections and then merge them with your DEM. Otherwise you will have to modify it the DEM in GIS or another program.
