Welcome to the RAS Solution › Forums › HEC-RAS Help › Depth 1D-2D Model
  • #6545
    I want create a map of max depth extent. I have a 1D-2D model, but when create a map and open this in GIS software, I look only depths that are in 2D cells and not the depth in 1D channel. How can resolve?
    Best regards-
    Antonio
    #10741
    Toby
    I bet you are using Crayfish?….
    Make your max depth map in RAS Mapper.
    Select depth in RAS mapper right click, edit map parameters -> select maximum, then save to disk. It will save in a new folder in your model directory.
    cheers,
