Hi, I would like to know if it is possible to set the number of decimal places in HEC-RAS when calculating the flow in the Hydraulic Design – Uniform flow window. For example, when I calculate the flow from a known water surface, I get 1 m3/s as the result, but I know that there is much less discharge. But I canť get more accurate results from this. Thanks for the reply. Jan
