Welcome to the RAS Solution › Forums › HEC-RAS Help › Dam Break Scenario
- This topic has 6 replies, 222 voices, and was last updated 6 years, 4 months ago by Anonymous.
November 15, 2019 at 12:36 am #7526AnonymousGuest
Hi All,
I have a unique situation that I’m trying to tackle and haven’t found the best solution yet. I’m running a dam break analysis where there is a concrete primary spillway and an earthen emergency spillway. Simple enough however, the emergency spillway flows to a pond that is offline from the primary spillway discharge point, into a small stream. Flow from the pond would then re-enter the stream further downstream of the dam via a closed conduit. What is the best way to set this configuration up in HEC-RAS? Currently I have the model successfully running the sunny day scenario as 1D with dynamic reservoir draw down, but this scenario doesn’t involve the offline pond.
Any insight would be helpful.
Thanks in advance,
MikeNovember 15, 2019 at 11:17 am #12617AnonymousGuestIf you are trying to stay all 1D:
I would model the dam and concrete spillway with an inline structure. I would use a lateral structure to model the emergency spillway that diverts water. The pond could be either a 1D storage area or a series of cross sections.
The closed conduit could be modeled using a culvert, gate, or cross sections with lids. If you use a culvert or gate, you could use another lateral structure to return the flow. For cross sections with lids, you would have to use a junction to return the flow.
In this approach, the dam break has to be either on the main inline structure or the lateral structure.
Another approach would be 2D. It could all be done inside of a single 2D area and the dam could be a single 2D connector. You would have to do the conduit as a gate or culvert (not cross sections with lids).
December 10, 2019 at 8:34 pm #12618AnonymousGuestI will give this a try and report back. Thank you for your help.
December 18, 2019 at 7:47 pm #12619THALLAM PRASHANTHParticipantsir i am doing dam break analysis in HECRAS 2D i am not able to rectify an error any one please tell me how to rectify it.
orrtl: severe (64): input conversion error, unit 39,
Error with program: RasUnsteady64.exe Exit Code = 64RasUnsteady64.exe 00007FF66A22A99D Unknown Unknown Unknown
RasUnsteady64.exe 00007FF66A21126A Unknown Unknown Unknown
RasUnsteady64.exe 00007FF66A20DDB2 Unknown Unknown Unknown
RasUnsteady64.exe 00007FF669DB655A Unknown Unknown Unknown
RasUnsteady64.exe 00007FF669C85C92 Unknown Unknown Unknown
RasUnsteady64.exe 00007FF669E7A172 Unknown Unknown Unknown
RasUnsteady64.exe 00007FF669D9F536 Unknown Unknown Unknown
RasUnsteady64.exe 00007FF669F24661 Unknown Unknown Unknown
RasUnsteady64.exe 00007FF669BBF121 Unknown Unknown Unknown
RasUnsteady64.exe 00007FF66A6CCE9E Unknown Unknown Unknown
RasUnsteady64.exe 00007FF66F7EB224 Unknown Unknown Unknown
RasUnsteady64.exe 00007FF66F7EB147 Unknown Unknown Unknown
RasUnsteady64.exe 00007FF66F7EB00E Unknown Unknown Unknown
RasUnsteady64.exe 00007FF66F7EB299 Unknown Unknown Unknown
KERNEL32.DLL 00007FFF8FBF7BD4 Unknown Unknown Unknown
ntdll.dll 00007FFF905ACED1 Unknown Unknown UnknownDecember 18, 2019 at 7:59 pm #12620cameronParticipantThis is a very generic error and cannot provide any real answer.
Does the model run without the breach?
December 18, 2019 at 8:02 pm #12621THALLAM PRASHANTHParticipantwhat we have to do to rectify this error please tell me
December 18, 2019 at 8:23 pm #12622THALLAM PRASHANTHParticipantyes
