Welcome to the RAS Solution Forums HEC-RAS Help Dam break connected with 2D Flow Areas
  • #6042
    Stefanoz
    Hi everybody
    I’m having problems with the following case, I try to explain as well as possible.
    I have a simple case described in the following link (https://www.dropbox.com/s/c5jfnw2rvn3j5z1/EA2DTest6%20-%20May2010.pdf?dl=0).
    I’ve developed the case drawing two 2D Flow Areas connected by a SA/2DFlow Area connection named “connessione” that represents the dam. (https://www.dropbox.com/s/rqa2b3w7jwrv5xg/Cattura.JPG?dl=0).
    In according to the case 6A I need to set two differents initial water height for the two differents flow areas.
    So my problem is: how could I describe the dam break in such a way that I have the instantaneos break?
    Should I consider it like an embankment? If yes, how could I set the values?
    Thank you for your interest
    Stefano
