I am performing a dam break analysis at culverts located at stream road intersections, assuming they have become clogged and are acting like dams, until they are breached. Accordingly, I do not put a culvert in the model, but instead am putting in a Weir as a SA/2D Area connection, and setup a breach plan for the structure. Here is my question:
Can I simply have the weir structure setup without having to remove the road material? Or do I have to carve out the road, with the area removed from the DEM equal to the width/length of the weir / dam I wish to model, before putting in the weir?
In other words, does putting in a SA/2D Area connection override the cell values that are present in the mesh that were generated form the DEM? Or does it not, and I have to alter the DEM to remove the road and road fill to the extent of my weir?
Tom
