Welcome to the RAS Solution Forums HEC-RAS Help Dam Break Analysis
  • This topic has 2 replies, 370 voices, and was last updated 11 years ago by Anonymous.
  • #5694
    I have modeled storage area, inline structure and downstream river reach in HEC-RAS for dam break analysis. After giving the boundary conditions, the model was run. But it is showing some stability problem. Discharges have negative values. I am not able to run the model because of stability problem. Can anyone suggest me what could be the problem?
    #9099
    sotiris
    I also have some stability problems with a dam break case. I also am a bit confused about the dam break hydrograph that is produced. Can someone help? Thanks in advance
    #9100
    Robert
    Hi
    I could help with your problem, but you have to send me printscreen or the betst is all project by debug report (Hec-RAS-File)
    Regards!
    Robert
