Welcome to the RAS Solution Forums HEC-RAS Help Dam Breach Validation Data?
  • #6725
    Is anyone aware of a dataset for a dam breach validation? This could either by data collected from a physical model or perhaps is there is something from a field case. I was looking for something with enough information where I could try out various simulation techniques and compare to the measured validation data set. Data set should have information on the problem setup and perhaps water surface elevations as a function of time downstream of the dam.
    #11108
    Here are a couple of reports on reproducing dam failure hydrographs with HEC-RAS. One is a laboratory flume and the other is the historical Teton dam failure. https://www.dropbox.com/s/4xrs7juwljdudia/RAS%20replication.pdf?dl=0
    Hope this helps,
    Michael
